Giant 20 Reign E+ 1 Pro
Vedi l'allegato 21175
FRAME ALUXX SL-grade aluminum, 160mm Maestro suspension system, 'Boost' 148x12QR, Giant EnergyPak Plus range extender compatible
FORK Fox 36 Float Performance 27.5+, 170mm, 3-position Micro Adjust Grip Damper, Boost 110x15QR, e-Bike optimized
SHOCK Fox Float X2 Performance, EVOL Large Volume sleeve, 2-position lever, 205x62.5mm Trunnion mount, custom tuned
HANDLEBAR Giant Contact Trail, 35x800mm
STEM Giant Contact SL 35
SEATPOST Giant Contact Switch, dropper, 30,9mm (S:100/M:125/L:150/XL:170)
SADDLE Giant Contact, Neutral
SHIFTERS Shimano Deore XT, 12-speed
FRONT DERAILLEUR MRP 1X custom "V3" co-moulded TR chain
guide
REAR DERAILLEUR Shimano Deore XT, 12-Speed, Shadow+
BRAKES Shimano Deore XT, BR-M8120, 4-piston, hydraulic disc, 203mm
BRAKE LEVERS Shimano Deore XT, BL-M8120
CASSETTE Shimano HG-M7100, 11-51T, 12-Speed
CHAIN KMC e.12 Turbo, EcoProteq, e-bike optimized
CRANKSET Praxis Wavetm 36T Cold Forged 4130 premium steel Praxis e-Cadet+ custom forged crankarm set (Q-factor=168, S/M:160, L/XL:165)
RIMS Giant e-TR1 27.5, Tubeless ready, 30mm inner width
HUBS Giant e-TR1 [F] 110x15 [R] 148x12mm Thru-axle
SPOKES Giant e-TR1
TIRES Maxxis Minion DHF 27.5x2.6" foldable, Tubeless, EXO+, 3c MaxxTerra[F] Maxxis High Roller II 27.5x2.6" foldable, Tubeless, DoubleDown, 2x120tpi, 3C MaxxTerra Compound [R]
EXTRAS Giant EnergyPak Smart 6A charger Tubeless kit (liquid, valves, levers, manual, tool)
MOTOR Giant Yamaha SyncDrive Pro
SENSORS Giant PedalPlus 6-sensor technology
DISPLAY Giant RideControl One
BATTERY Giant EnergyPak Smart 500, 36V 13.8Ah integrated Lithium-Ion
Giant 20 Reign E+ 2 Pro
Vedi l'allegato 21176
FORK Fox 36 Float Rhythm 27.5+, 170mm, Grip Damper, Sweep adjust, Boost 110x15QR, e-Bike optimized
SHOCK Fox Float DPX2 Performance, EVOL Large Volume sleeve, 2-position lever, 205x62.5mm Trunnion mount, custom tuned
SHIFTERS SRAM GX Eagle 12-speed
FRONT DERAILLEUR MRP 1X custom "V3" co-moulded TR chain guide
REAR DERAILLEUR SRAM GX Eagle 12-speed
BRAKES SRAM Guide RE, 4-piston, hydraulic disc, 200mm
BRAKE LEVERS SRAM Guide RE
CASSETTE SRAM Eagle PG-1230, 11-50T, 12-Speed
CHAIN SRAM NX Eagle PowerLock, 12-speed
CRANKSET SRAM X-Sync Eagle 36T 104BCD chainring Praxis e-Cadet+ custom forged crankarm set (Q-factor=168, S/M:160, L/XL:165)
RIMS Giant AM 27.5+, Tubeless ready, 35mm inner width
HUBS Giant eTracker Boost, Sealed cartridge bearing, 6-bolt, [F] 110x15 [R] 148x12mm Thru-axle
SPOKES Sapim E-Lite [r] Race [f]
MOTOR Giant SyncDrive Pro
