Problem battery 48v BMS 30amps and motor of 1000watts disconnecting after few minutes
maxlucca
27 Agosto 2021
Italy
Ebike self build motor 1000watts battery hilong 48volts 30amps
Dear forum hi, I need help to fix my battery turning off after few minutes on full trottle! I did contact the BMS manufacture with no anwer.
I have a hailong battery 48v 13ah with BMS on my bike with motor of 1000watts … I need support to fix it:
the battery seem still good I did bought new on november 2019 I did charge about 10 times but now I'm getting an error low voltage after few Km of running,
I did charge it and after few km it disconnect again.. seem no charging completely, I did test the voltage is about 50,8 volts after charge, and if I run the motor on ebike without person over it.. the motor is not spinning regulary but motor increase and decrease the speed of rotation by itself !
Could be the BMS defective? The BMS is: Bestway BWPB 352 13S 30A 12X37 0546GXX …
How can I test BMS and cells? I want to be sure where the broblem is: bms or cells… Any help is welcome
Thanks you. Best regards Max Italy
marco
Pachidermica©
Diretur
13 Settembre 2016
4.285
6.407
Monte Bar
www.mtb-mag.com
Diverse
TC
KM Percorsi
ma perché scrivi in inglese?
ivo
11 Novembre 2016
3.862
2.408
Medolla (MO)
Canyon Spectral:On 7.0
Ma parla come mangi.
