Giant Trance SX E+ Pro 2019 - parte 3
Andyz_it
4 Aprile 2018
1.439
497
53
Tortona
Giant Trance E+ SX 1 Pro
Novità 2021, cercando in rete sul sito dove vidi per la prima volta le trance con batterie da 625 ho trovato che hanno già a listino i modelli 2021, non ci sono ancora foto per quanto riguarda le colorazioni, vi metto l'allestimento :
Trance X e+1 PRO 29"
FrameALUXX SL-grade aluminum, Advanced forged composite upper rocker, 140mm Maestro suspension system
ForkFox 36 Float Performance, 150mm travel, 44mm offset, Grip 3-position, Micro Adjust damper, Boost 110x15QR, e-optimized
ShockFox Float DPX2 Performance,EVOL Large Volume sleeve, 3-Pos Lever, 185x52.5mm Trunnion mount
HandlebarGiant Contact 35 Trail, 35x780mm
GripGiant Tactal single lock-on
StemGiant Contact SL 35
SeatpostGiant Contact Switch, dropper, 30,9mm (S:125, M: 150, L/XL:170)
SaddleGiant Contact Trail, Neutral
PedalFlatpedal
ShiftersShimano Deore XT, 12-speed i-spec EV
Front DerailleurMRP 1X custom "V3" co-moulded TR chain guide
Rear DerailleurShimano Deore XTR, 12-Speed, Shadow+
BrakesShimano Deore XT, BR-M8120, 4-piston, hydraulic disc, 203mm
Brake LeversShimano Deore XT, BL-M8120 i-spec EV
CassetteShimano CS-M7100-12, 10-51T, 12-Speed
ChainKMC e.12 Turbo, EcoProteq, e-bike optimized
CranksetPraxis Wavetm 36T Cold Forged 4130 premium steel
Praxis e-Cadet+ custom forged crankarm set (Q-factor=168, XS/S:160, M/L:165, XL:170)
Bottom BracketN/A
RimsGiant e-TR1 29, Tubeless ready, 30mm inner width
HubsGiant e-TR1 [F] 110x15 [R] 148x12mm Thru-axle
SpokesGiant e-TR1
TiresMaxxis Assegai 29x2.6" foldable, Tubeless, EXO, 3c MaxxTerra[F]
Maxxis Dissector 29x2.6" Foldable, Tubeless, EXO+, 120tpi 3C Compound [R]
ExtrasGiant EnergyPak Smart 6A charger
Tubeless kit (liquid, valves, levers, manual, tool)
Inner tube supplied
MotorYamaha/Giant SyncDrive Pro
ControlsGiant RideControl One remote
DisplayGiant RideCotrol Plus wireless (optional)
BatteryGiant EnergyPak Smart 625, 36V 17.3Ah integrated Lithium-Ion
Trance X E+2 Pro 29"
ForkFox 36 Float Rhythm, 150mm travel, 44mm offset, EVOL, Grip Damper, Sweep adjust, Boost 110x15QR, e-optimized
ShockFox Float DPS Performance, EVOL Large Volume sleeve, 3-position Lever, 185x52.5mm Trunnion mount, custom tuned
PedalFlatpedal
ShiftersShimano SLX 12-speed i-spec EV
Front DerailleurMRP 1X CS custom
Rear DerailleurShimano Deore XT, 12-Speed, Shadow+
BrakesShimano Deore BR-M6120, 4-piston, hydraulic disc, 203mm
Brake LeversShimano Deore BL-M6120 i-spec EV
CassetteShimano CS-M6100-12, 10-51T, 12-speed
Bottom BracketN/A
RimsGiant AM 29", Tubeless ready, 30mm inner width
HubsShimano Boost, Center-Lock, [F] 110x15 [R] 148x12mm Micro-Spling Drive Body Thru-axle
SpokesSapim E-Lite [r] Race [f]
TiresMaxxis Assegai 29x2.6" foldable, Tubeless, EXO [F]
Maxxis Dissector 29x2.6" Foldable, Tubeless, EXO+ [R]
Inner tube supplied
Trance X E+ 3 PRO 29"
ForkRock Shox 35 Gold RL DebonAir, 150mm travel, 44mm offset, MotionControltm rebound and lockout control, 15x110 Boost, Maxle Stealth
ShockFox Float DPS Performance, EVOL Large Volume sleeve, 3-position lever, 185x52.5mm Trunnion mount, custom tuned
PedalFlatpedal
ShiftersShimano Deore 12-speed i-spec EV
Rear DerailleurShimano Deore 12-speed
BrakesShimano BR-M420, 4-piston, hydraulic disc, 203mm
Brake LeversShimano Deore BL-M4100 i-spec EV
Praxis e-Cadet+ custom forged crankarm set (S/M:160, L/XL:165)
Bottom BracketN/A
Inner tube supplied
Reactions: bogiacche
Andyz_it
4 Aprile 2018
1.439
497
53
Tortona
Ci sarà anche un faretto già cablato per le nostre bike comandabile dal Ridecontrol, ma non ho capito se è prodotto da giant o da terze parti
WEB_Image%20E-bike%20Frontlys%20High%20Power%201000LM%20Yamaha%20ebl-301j-6v346567102.Jpeg
le caratteristiche lo danno per 1000lumen
Aggiungo per le trance 2021, potrebbe esserci un'aggiornamernto per quanto riguarda la protezione motore, se notate dalla foto della LIV 2021 (unica che si vede) ha la protezione simile alla reign, potrebbe essere che l'hanno fatta anche sulla trance
WEB_Image%20Giant%2021%20Liv%20Intrigue%20X%20E%20%203%20Pro%2027%205%20XS%20210334410271351030.Jpeg
vedremo......
Andyz_it
4 Aprile 2018
1.439
497
53
Tortona
Interessante o preoccupante invece perchè leggendo le specifiche nella trance indicano :
Controls : Giant RideControl One remote
per la stance 2021 invece :
Controls : Giant RideControl One remote ANT +
Errore o ..... peggio?!?
